PeterJames Posted January 1, 2017 Posted January 1, 2017 14 minutes ago, alanfox said: probable would go for the standard kit with no additional cost, do not want to pay £72 each year just to have access to the homeapp. 20p a day sounds reasonable to me 1 Quote
al-yeti Posted January 1, 2017 Posted January 1, 2017 33 minutes ago, MrHappy said: I had app panel on a wired card as test system on a bench After testing it & getting notifications on alarm ectt.. I left it unplugged for months & never got any indication that it wasn't working via the app But it's diy , what you want to be notified for? 3 hours ago, alanfox said: I am looking at purchasing a Pyroniox Enforcer and I am tried to understand the different modules available to buy: Enforcer PSTN kit - This is just the stand alone system with no contract, just siren sound. probable the most commonly used system by DIYs. Enforcer GSM Modem - This only texts messages to your mobile phone about the status of your Enforcer. Are there are additional cost? Enforcer PSTN Modem - This one connects to your phone system. Assume this one would have cost to run each month. Enforcer HomeControl+ - This one is the system that you can control from mobile app and you can add CCTV cameras. I am planning to add CCTV camera to the system at the later date and would like to access the Enforcer from mobile app or computer. Should I look at purchased the Enforcer HomeControl+. Do I connect the Enforcer via home broadband LAN connection to get the internet connection. Do I need to pay for any additional cost to run this system each month? Option one Or option 2 with contract sim Quote
MrHappy Posted January 1, 2017 Posted January 1, 2017 52 minutes ago, al-yeti said: But it's diy , what you want to be notified for? silly me I thought it where an alarm... Quote Mr Veritas God
Simlec Posted January 1, 2017 Posted January 1, 2017 5 hours ago, MrHappy said: I had app panel on a wired card as test system on a bench After testing it & getting notifications on alarm ectt.. I left it unplugged for months & never got any indication that it wasn't working via the app Well you would if you were using the system correctly (setting/Unsetting notifications switched on) as you would not have received and notifications when using the system, but yes they need a push notification for polling failure which i think could/should be done. Quote
MrHappy Posted January 1, 2017 Posted January 1, 2017 1 hour ago, Simlec said: Well you would if you were using the system correctly (setting/Unsetting notifications switched on) as you would not have received and notifications when using the system, yes got open+close / alarm, tamper alarm 1 hour ago, Simlec said: but yes they need a push notification for polling failure which i think could/should be done. so it don't do polling ? so go on holiday, cut the line external of the premises & have all the time in the world to rob the property Quote Mr Veritas God
norman Posted January 1, 2017 Posted January 1, 2017 Sounds a bit poor. Quote Nothing is foolproof to a sufficiently talented fool.
petrolhead Posted January 1, 2017 Posted January 1, 2017 It is a bit. It does poll the cloud regularly, but no notifications of polling fails. Quote
norman Posted January 1, 2017 Posted January 1, 2017 So what's the point of polling? Quote Nothing is foolproof to a sufficiently talented fool.
Simlec Posted January 1, 2017 Posted January 1, 2017 1 hour ago, MrHappy said: yes got open+close / alarm, tamper alarm so it don't do polling ? so go on holiday, cut the line external of the premises & have all the time in the world to rob the property You get that with a standard PSTN device as well as any wifi coms. No it currently will not send you a push notification of polling problems like most of the other brands out there (I will email them to see if it can be added), unless you have the ARC GSM module and then your are monitored anyhow. Quote
norman Posted January 2, 2017 Posted January 2, 2017 1 hour ago, norman said: So what's the point of polling? Quote Nothing is foolproof to a sufficiently talented fool.
