The current system installed is honeywell as follows;
8SP399A Accenta min g4 panel (unsure)
8IR100 Pir sensors (grade 2)
8EP420 reason 8 bell box (grade 2)
8EP276A informa  speech dialer (unsure)
SS/01 simple set reader (unsure)
The insurance require the alarm system to registered with nsi or ssaib installer therefore would like to know what grade is system overall and what will need to replaced to make alarm compatible to be on contract ?
Thanks in advance.
so the upgrade would mean grade 2 alarm panel with keyfob such as galaxy 2-12 ?
the company that take on maintenance contract will replace voice dialler with an arc device ?
  • 2 weeks later...
Posted (edited)
Thanks for all your replies here is extract from insurance company
towergate_insurance.pdf
see section 8zz2 alarm clause
I need to know if current system which is bs4737 put under contract or will they have to upgrade system ?
Edited by btssn
addition
It just has to have a maintenance contract, obviously they are expecting you to check that it is in good working order. The insurance co has not asked for anymore than that though.
