Hi can anyone pls help I have a galaxy 96  and am trying to get the keypads (2) to beep if ct 1011 programmed as log zone activates,   ct 1011 is from a mains relay via a outside light ie if anyone walks on the drive the light lights and the key pads bleep ( not ent ex horn as  to loud) I did the sometime back on a gal 60 via links and outputs and I think reprogramming the key pad outputs
many thanks
Thanks for the reply but chime fires the internal speaker, have now sorted it by programming k pad outputs to link a and setting links to ct 1011 source and destination to link a works fine
