Guest thedeester1 Posted October 25, 2004 Posted October 25, 2004 Hi this is my first post here. Thnx in advance to any who help. Scantronic 9448+ Ive just purchased a property with view of renovation. The problems i have is that the previous occupant died of old age and none of the family members ive been in touch with have any idea of the user code and that the documentation seems to have disapeared when the house was cleared. When i got the house the fuse was pulled from the spur and all the bell box wiring had been disconnected. Probably to stop alarming without possible reset. I have two questions firstly does anyone have the engineer and default code for this alarm and if possible does anyone have a full set of documentation ie instalation and user manuals. I am an electrical engineer but have to admit my knowledge of alarms is limited and the terminals in the bell box dont match up to the ones in the panel. I will also be adding new zones and fitting door switches and pressure pads. I think i have worked out where all these go but would like to make sure. I realise that you may not post this information here but would be gratefull if someone could mail me. I tried getting a user account on the scantronic website but my possition as an engineer in charge of around 40 electricians didnt seem to be enough. My mail Mistadee@blueyonder.co.uk
Guest RICHL Posted October 26, 2004 Posted October 26, 2004 Wouldnt touch pressure pads with a bargepole mate why not get a local installer in to do it all for you?
ian.cant Posted October 26, 2004 Posted October 26, 2004 Same here, Pads are ok at 1st then they breakdown inside and cause flase alarms. Also you would have to mess about with relays as they work the wrong way round!
