Hi, I am hopeful that someone may be able to assist me with locating a Nexus 8 remote keypad. My son has just moved into his new house and the house is fitted with a nexus 8 alarm panel and has a remote keypad in the side entrance to the house. This is  fine when exiting and entering the property but if you want to set the alarm whilst in the house  ie whilst up stairs   and omit zones the keypad being in the side passage way this   makes it impracticable. So I am intending to fit a second keypad by the stairs.
I have attempted to search online in an attempt to buy one but cannot find one. Does anyone know of a supplier.?
Regards.:)
Try searching lyntek or is it lyntec in the name you might find one , unless I got it wrong ...... I just a trainee need a monkey to show up and confirm it
Its Defender tat AFAIK I ripped one out last year, metal case made of bean tins I think, try cpc.co.uk op
I use CPC and have checked but no sign of the make, from what you say sounds like it may be better to change the panel and keypad.Nexus 8 keypad.jpg
About 20yrs ago I was offered one as sample, I declined....
A "new old stock" one will appear on fleabay, personally you'd be better off  replacing with something decent
Yes I think it is Lyntech and I emailed them but got no reply. I think I will tell my son that it may be better to change the the lot. cheers for the replies.
Ah now I've seen the pic it's not Defender, no. But it is still tat ;)
A Scantronic 9651 or similar will be a good replacement.
