does look like paxton, i have the manuals for all the newer stuff but not sure if the programming would be the same. do you have the programming code?
might need a reset then to default, set a new programming code then set new user code. is this a stand alone reader or connected to a switch2? of course you might open a box near by and find its not paxton at all
Standalone. It's working at moment so unless can get a manual the code is staying the same. Site not interested in updating to our standard kit
