Hello,
I have an application, a parking space, where i need to detect fire and to sound an outdoor alarm, some indoor sirens and to start the fans of the ventilation system.
My addressable fire panel has the following 5 types of outputs:
1. One FIRE ALARM OUTPUT - Non-Supervised:
2. One NAC FIRE ALARM OUTPUT - Supervised
3. Eight Programmable—Supervised ALARM Outputs
4. Eight  Programmable—NON Supervised ALARM Outputs
5. Three NAC Supervised Outputs.
I found that there is another possibility, 6. to use an I/O Module which i can wire in my loop.
I just started in this field, i don't know which type of outputs should i use for my devices (outdoor siren, indoor sirens and to start the fans).
Can anybody tell me, what would be the best way to use these types of outputs for my particular case?
Sounds like a U.S. setup, it may be best to consult someone in your locality with regards to regulations etc, as this is primarily a UK site and we work to different standards and with differing equipment.
  • Upvote 1
Trade Member
