No different to buying a new mobile phone now or tv for it to be out of date 6 months later.
If it was out of date then so be it.  But really i must bin this system because it out of date tac.  I might do that with all my stuff i have.  I chuck my samsung galaxy 7 in the bin now because it now out of date. And i bin my 4 k tv as there is a newer version.
Fully understand the points you chaps have made on here. Pay my money make my choice.
Call out and a fix and a maintance contract or fix it myself and fit a new sensor.
Life span of batteries in bell box and control panel will most likely be 7 years so they will need changing.  So may be in a few years time and i can afford to change the system i will. By that time the current best systems will to be out of date will they not?
Total blag
If you don't mind me saying , no offence of course , but you know your choices
alarms ain't consumer devices, their niche market low volume & expensive for old tech
the same doors contacts are still being sold, only the very early one are unavailable as they changed the mhz ?
ring risco & ask who'd they recommend locally
  • Downvote 1
Can he swap it for lightsys I thought they were ok? Some detectors might work with it
you did?
sensors ish and bells only imo
3 minutes ago, james.wilson said:
you did?
Nah think H said they were ok so.etime back or the lightsys or prosys or whatever they call it
I reckon I could sort this system in under an 1hr, should the device report a low battery with the next 28 days I'return & just charge for the device I have old types & new on the shelf.
The other topic with Everest abacus, again sorted within an 1hr,
Both could have fully comp contracts, however I probably start with wanting money for bells & batterys to put money in the pot
Thanks for your honest views, no offence taken by any.  I email a few local companies from your listing in my area for they advise on cost etc before i spend any thing on this system now
The correct actual system is a risco eurosec cpx with the standard eurosec key pad and the 8 zone wireless expander.   not that if it would make much odds from what you chaps have said on here about it.
