Guest ashenfie Posted October 27, 2004 Posted October 27, 2004 Hi, First time i've used these boxes & all else works ok. The Box triggers on zones 6&7 randomly. I put the links back in the box to ensure it's not a sensor/wire issue and the Zones still triggers during the walk around test. Have I missed something? Alex
Mister_Dave Posted October 27, 2004 Posted October 27, 2004 With the excel it is an eol panel, try changing the link for a resistor. Dave Oxendale York based security systems engineer.
Guest ashenfie Posted October 27, 2004 Posted October 27, 2004 With the excel it is an eol panel, try changing the link for a resistor. 29522[/snapback] I have tried the panel in EOL & Normal Modes, same happens.
Adi Posted October 27, 2004 Posted October 27, 2004 Excel is EOL or global. I think it might the panel at fault. Have you tried phoning or e-mailing Texecom. I really can't be ar**** with it anymore.
breff Posted October 27, 2004 Posted October 27, 2004 sounds like faulty panel The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest ashenfie Posted October 29, 2004 Posted October 29, 2004 sounds like faulty panel 29559[/snapback] Thanks for you replies, New box solved all my problems
