Attempting to upgrade my old alarm system. Can anyone please advise? Fitting a new Gardtex RISC 490X control panel. I need to wire my old Vipers wiring in order for the power source to be ceased when I need to reset the viper.  How can I wire the old vipers in the control box? Thanks.
Hi,
That's not a panel that many will be familiar with, although I could be wrong - did it come with an installer manual?
Can be done , just wire the +v to one of the outputs and program accordingly.
they will then reset automatically.
2 hours ago, datadiffusion said:
Hi,
Hi, It did come with a installer manual but it doe's not tell you how I can wire into my Gardtec 490X control Panel my old Vipers that need power removing to reset.
Hi, Can the Gardtec 490X control Panel be programed to remove the power source to reset the old type Vipers.
