2 minutes ago, al-yeti said:
Are used ones not cheap on eBay?
They are, but I thought it would be a shame to pull them apart if they are still working. Just wondering because someone here may have taken one out, and doesn't want any money for the old panel, just postage, which I'd happily pay.
Lol alarm monkeys keep them in service Aslong as possible
Ah, right. I see. Do Honeywell still do those larger ADE Poly-carbonate cases? I may ring and ask.
9 hours ago, sixwheeledbeast said:
I wouldn't worry about that, they're unlikely to be put back in service.
Do you have any old alarm plastic cases kicking around?
I tend to butcher plastics & pcbs when removing
Friday night I changed a 9 circuit Euro 12 c/w old metal zem into 76M that I had on stock.
I unscrewed the speaker, scb & rkp then chopped the euro 12 pcb in half, hacked away at the plastics & until the pcb would pass out the back of the old cabinet, removed old zem from metal cabinet & mounted pcb into new endstation.
1.5hrs on site, everything texted up & tested.... however new cabinet did look a bit pissed on the wall when I stood back to admire it.
  • Upvote 2
Ha, oh dear! Oh, well. I will keep on the look out, or get some sort of plastic box. Do you have any old transformers for alarm panels? Just need one for my Accenta
One of these? While was doing a "h" with bit plumbing refurb stud wall etc it was taken out
Yeah, an Accenta like that, or just the transformer out of it. Do you still have it? If it was taken out.
The grab claw doesnt have a TX
