Dan Pearce Posted February 13, 2017 Posted February 13, 2017 Hi I have just bought an apartment following a death, the alarm system is currently disabled in the fuse box as the vendors family were not aware of the code for the alarm, I have tried to use the factory default code to reset the alarm but this has evidently been unsuccesful, can anyone advise how I can get the system back to the factory defaults given as soon as I turn it on all the alarms sound and all the panel indicators go red? Quote
al-yeti Posted February 13, 2017 Posted February 13, 2017 Sounds to me it's been shut off because of faults , and even factory defaulting won't help you, even though that info isn't not given out on this site If it was working most systems just sit there happily in standby and if shut down because whatever fault occurred they didn't want the expense to fix it Quote
aissecur Posted February 14, 2017 Posted February 14, 2017 As you don't know anything about the functionality / quality of the system installed I would suggest the best way forward would be to call out an approved alarm engineer to take a look at the system and advise on the best way forward. Quote
Hillbilly Posted February 14, 2017 Posted February 14, 2017 To be fair you could easily get the info you require just by searching google. Quote
al-yeti Posted February 14, 2017 Posted February 14, 2017 3 hours ago, aissecur said: As you don't know anything about the functionality / quality of the system installed I would suggest the best way forward would be to call out an approved alarm engineer to take a look at the system and advise on the best way forward. He means an engineer "approved " is very vague Quote
