iwols Posted February 21, 2017 Posted February 21, 2017 hi all just installed a new camera(DS-2CE56D7T-IT3Z )hickvision motorized , which has just a zoom and focus option,im using it with the 7208 hickvision turbo dvr,i can get the zoom and focus to work ok with the switch that is on the camera,but when I use it through the ptz controls via the dvr once I press + or - zoom or + or - focus the camera just constantly does whatever I pressed even when I release the button and I have to disconnect the power to the camera to stop it,am I missing a setting somewhere thanks Quote
al-yeti Posted February 21, 2017 Posted February 21, 2017 Does it have different protocol settings? Quote
iwols Posted February 21, 2017 Author Posted February 21, 2017 thanks but different protocol settings ?? Quote
iwols Posted February 21, 2017 Author Posted February 21, 2017 the ptz protocol setting is set to hickvision-C(coaxitron) if that helps Quote
al-yeti Posted February 21, 2017 Posted February 21, 2017 51 minutes ago, iwols said: thanks but different protocol settings ?? Example I do the really know him but Samsung has a couple of protocols and wrong settings can make the menu skip UART settings etc , if that's the right word so thought maybe as a remote device controller that's why it was doing that , as on the cam it will always work Quote
petrolhead Posted February 21, 2017 Posted February 21, 2017 Probably **** cable or power. Try local power or. Remove camera and taking it to the dvr with a short patch cable. Quote
iwols Posted February 22, 2017 Author Posted February 22, 2017 tried the thicker type wire and all ok now thanks guys Quote
