norman Posted February 26, 2017 Posted February 26, 2017 Fleabay Quote Nothing is foolproof to a sufficiently talented fool.
james.wilson Posted February 26, 2017 Posted February 26, 2017 1 hour ago, datadiffusion said: Oh. I think we were all thinking SW? doubt it, its a few pallets a week Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Hillbilly Posted February 27, 2017 Posted February 27, 2017 If the battery voltage is below 11.8v the alarm will notify you with a fuse/battery fault. put the battery onto the panel and leave for a few hours then test with meter. To truly see if you have a duff battery it needs to be tested for Amp Hours aswel. Quote
karl taylor Posted February 27, 2017 Author Posted February 27, 2017 Hi sorry for delay Old battery reads: 13.60volts New battery which i am sending back reads: 11.28 volts!! What should a new battery be as i have just ordered another one from some where else but dont think i should have bothered? 1 Quote
norman Posted February 27, 2017 Posted February 27, 2017 Have you charged it ? Quote Nothing is foolproof to a sufficiently talented fool.
karl taylor Posted February 27, 2017 Author Posted February 27, 2017 Have kept the original battery in the control panel. reading says 13.60 volts. Am waiting on a another battery coming from some where else. No not off dodgy ebay What should a new battery readings be as done see any point in getting it Quote
sixwheeledbeast Posted February 27, 2017 Posted February 27, 2017 The new battery maybe slightly discharged but should come with at least 12.0v Quote
karl taylor Posted February 27, 2017 Author Posted February 27, 2017 Just tested the so called new battery that i am sending back with a different multi meter. Reading now 11.15 volts. So it most likely old stock. Is there any point in changing my exsisting battery if its reading 13.60 volts? even though its five years old. Not sure any point now. Or even though its showing high ok voltage it will be failing? As people have said its a serviceable item and needs changing due to its age. Why? Quote
karl taylor Posted February 27, 2017 Author Posted February 27, 2017 Ok thanks for that i check it when i get it. 12 volts should be 12volts capacity. Understand that. But why am i getting a reading of 13.60 volts from my original battery thats 5 years old. Surely it should be lower than 12 volts? or is it getting over charged to compensate for voltage drop by the alarm system? Quote
