Scantronic 9200 programming
Guest apollo
Guest apollo
Hi
I have been trying to find out how to change entry/exit times on this panel. Also, for future queries, an engineers manual would be appreciated as I work in the industry but cannot find one.
cheers
1st things 1st, are you trying to program the times with the main panel lid closed? Older scantronics wouldnt allow any change of settings until the panel was in Enginner mode and the panel cover was opened up with the tamper spring open. Check no previous alarm companies have defeated the tamper spring to stop it opening when the front is undone otherwise it wont accept anything.
Assuming you know how to gain access to engineer programming. (0, enter, enginner code)
Press in 43 followed by Enter and then the selection for the amount of time you want followed by Enter. For example.
43, Enter, 1 Enter gives you 20 Secs Entry time.
43, Enter, 2 Enter gives you 40 Secs Entry time.
43, Enter, 3 Enter gives you 60 Secs Entry time.
43, Enter, 4 Enter gives you 120 Secs Entry time. (2mins)
43, Enter, 5 Enter gives you 180 Secs Entry time. (3mins)
43, Enter, 6 Enter gives you 240 Secs Entry time. (4mins)
43, Enter, 7 Enter gives you 600 Secs Entry time. (10mins)
43, Enter, 8 Enter gives you Infinate Secs Entry time. (endless)
Press in 44 followed by Enter and then the selection for the amount of time you want followed by Enter. For example.
44, Enter, 1 Enter gives you 10 Secs Entry time.
44, Enter, 2 Enter gives you 20 Secs Entry time.
44, Enter, 3 Enter gives you 30 Secs Entry time.
44, Enter, 4 Enter gives you 60 Secs Entry time. (1min)
44, Enter, 5 Enter gives you 90 Secs Entry time. (1.5mins)
44, Enter, 6 Enter gives you 120 Secs Entry time. (2mins)
44, Enter, 7 Enter gives you 300 Secs Entry time. (5mins)
44, Enter, 8 Enter gives you 600 Secs Entry time. (10mins)
Post again if this gets stuck.
P.S Dont quote me on the panel lid needing to be open thing as it's been years since i saw a 9200. (Thanks gawd)
Guest Adrian
B) Hi Apollo
If you PM me your e-mail address I will send you the manuel.
Adrian B)
Guest Adrian
B) Hi apollo
The manuel should be with you
Adrian B)
Guest apollo
Exactly what I needed. Thanks guys:D
Unfortunately the engineer code has been lost in the sands of time so I think I might have to default it and reprogram. Shouldn't be a problem with the manual now though.
