firemonkey Posted March 3, 2017 Posted March 3, 2017 Hi all, I have a Galaxy Dimension and have a GT-20 IP module here, can I use that to connect to the RSS and also use the remote control app or do I need to have the E080 ethernet module? Thanks Quote
GalaxyGuy Posted March 3, 2017 Posted March 3, 2017 You can use RSS, but not the Honeywell GX app. You can use my Galaxy Virtualkeypad remote control app (iPhone / Android) with any IP module. Quote
firemonkey Posted March 3, 2017 Author Posted March 3, 2017 Thanks, I was hoping to use the app. Looks like will have to eBay the GT-20 and get the ethernet module instead. Has been a while since worked with intruder so a little rusty on anything app connected! Getting back into it though, have been doing fire for too long that brain cells die off Quote
al-yeti Posted March 3, 2017 Posted March 3, 2017 Gx keypad is not as good as the virtual keypad in my opinion, just need sites with virtual keypad to make it better Quote
GalaxyGuy Posted March 3, 2017 Posted March 3, 2017 25 minutes ago, al-yeti said: Gx keypad is not as good as the virtual keypad in my opinion The app could be better. 25 minutes ago, al-yeti said: just need sites with virtual keypad to make it better Yes, I know. I have it for the iOS including push notifications for SelfMon, but I still have to update the Android app before I release it. I've been busy working on a new lower cost Ethernet module based on the USR-K3 with an integrated ARM processor. The design had a bug in FreeRTOS which was driving me crazy, but I fixed that on Thursday evening, so can continue with the rest of the coding. I have included a direct HTTP interface and it works very well. I'll probably make an alternative firmware available for customers to flash in themselves to gain HTTPS, as licensing the SSL libraries to deliver with the hardware costs £3.5k and that would bump up the cost of the module itself. Here's the prototype so far. This one is RS485, but there's also the option for RS232 and that opens up the possibility of using this with Texecom panels as a cheaper solution to COM-IP. 1 Quote
GalaxyGuy Posted March 3, 2017 Posted March 3, 2017 1 hour ago, firemonkey said: Thanks, I was hoping to use the app. Looks like will have to eBay the GT-20 and get the ethernet module instead. Has been a while since worked with intruder so a little rusty on anything app connected! Getting back into it though, have been doing fire for too long that brain cells die off The Honeywell GX app will only work on the Honeywell E080-2/4 & A083 (Flex) Ethernet modules. The E080-2 should be at V2.11 and the E080-4 should be at V3.06 to work with all combinations of panels. Quote
al-yeti Posted March 3, 2017 Posted March 3, 2017 14 minutes ago, GalaxyGuy said: The app could be better. Yes, I know. I have it for the iOS including push notifications for SelfMon, but I still have to update the Android app before I release it. I've been busy working on a new lower cost Ethernet module based on the USR-K3 with an integrated ARM processor. The design had a bug in FreeRTOS which was driving me crazy, but I fixed that on Thursday evening, so can continue with the rest of the coding. I have included a direct HTTP interface and it works very well. I'll probably make an alternative firmware available for customers to flash in themselves to gain HTTPS, as licensing the SSL libraries to deliver with the hardware costs £3.5k and that would bump up the cost of the module itself. Here's the prototype so far. This one is RS485, but there's also the option for RS232 and that opens up the possibility of using this with Texecom panels as a cheaper solution to COM-IP. Will there be a secret trade only function? Quote
GalaxyGuy Posted March 4, 2017 Posted March 4, 2017 The good thing about this design is that the firmware can be upgraded from the LAN in less than 5 seconds. This makes it easier to create special firmware to do things like dumping out settings/PINs. I would probably lock those to specific 'engineers' hardware. Quote
GalaxyGuy Posted March 4, 2017 Posted March 4, 2017 1 hour ago, firemonkey said: Thanks, I was hoping to use the app. Looks like will have to eBay the GT-20 and get the ethernet module instead. Someone else had the same idea with the two they had the other day... http://offer.ebay.co.uk/ws/eBayISAPI.dll?ViewBidsLogin&item=122376450807&rt=nc&_trksid=p2047675.l2564 Quote
firemonkey Posted March 4, 2017 Author Posted March 4, 2017 Thanks all for your help Ive just downloaded the virtualkeypad app and will have a play around with it Quote
