theengdom Posted March 5, 2017 Posted March 5, 2017 Hello, Looking like an interesting forum; currently have a collection of Visonic parts mainly eBay purchases now looking at making them all work. I've won as apart of some of my purchases a Visonic PowerMaster 360. The first real issue so far is default installer code. I've factory reset the panel, can access it via Power Master configuration version 1.0.3.04 using the default 'user' (in some manuals) code of However when I come to entering either the master code, or installer code of it's throwing me a 'wrong password' error. The panel looks to be an ADT thus I suspect the firmware could be different. Any ideas of processing forward. PM possible installer codes? Or does anyone have any default Visonic Firmware I can upload to the box. Thanks in advance Quote
PeterJames Posted March 5, 2017 Posted March 5, 2017 Hi Welcome We are unable to give out any defaulting information on this forum for obvious reasons Quote
PTD Posted September 26, 2020 Posted September 26, 2020 Hi Theengdom, Did you get anywhere with your ADT PM360R as I'm in the same position as you. Regards Quote
al-yeti Posted September 26, 2020 Posted September 26, 2020 On 26/09/2020 at 12:21, PTD said: Hi Theengdom, Did you get anywhere with your ADT PM360R as I'm in the same position as you. Regards Expand Yes many are Quote
