norman Posted March 12, 2017 Posted March 12, 2017 Striking resemblance actually. Quote Nothing is foolproof to a sufficiently talented fool.
datadiffusion Posted March 12, 2017 Posted March 12, 2017 Lol Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
aissecur Posted March 20, 2017 Posted March 20, 2017 At home I installed a inline Sure stop solenoid just after the incoming stop tap, has a meter of "Flex" that allows you to mount the isolation switch in a convenient / accessible location. Nice & easy to install. Always ensure the water to the house gets switched off if away for a few days or on holiday! http://www.surestop.co.uk/owners/ Quote
Simlec Posted March 20, 2017 Posted March 20, 2017 24 minutes ago, aissecur said: At home I installed a inline Sure stop solenoid just after the incoming stop tap, has a meter of "Flex" that allows you to mount the isolation switch in a convenient / accessible location. Nice & easy to install. Always ensure the water to the house gets switched off if away for a few days or on holiday! http://www.surestop.co.uk/owners/ When you say "flex" you mean pipe that's connected to the air switch? Quote
norman Posted March 20, 2017 Posted March 20, 2017 I'd say so. Quote Nothing is foolproof to a sufficiently talented fool.
sixwheeledbeast Posted March 20, 2017 Posted March 20, 2017 I don't think I could trust push fit, especially on a supply or rising main. Quote
norman Posted March 20, 2017 Posted March 20, 2017 My incoming is plaggy compression, not much better tbf Quote Nothing is foolproof to a sufficiently talented fool.
datadiffusion Posted March 20, 2017 Posted March 20, 2017 To be honest I'd trust a £30 John Guess push fit valve converting rising main MPDE to copper / push fit over those hideous Screwfix £7.99 'MDPE one end, 15mm the other' Chinese made valves that most modern houses seem to have. http://www.screwfix.com/p/poly-stop-cock-25mm-x-15mm/86048 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
aissecur Posted March 21, 2017 Posted March 21, 2017 sorry yes that is correct - reason I said flex is its a similar size / shaped to a 1.5mm twin & earth Quote
datadiffusion Posted March 21, 2017 Posted March 21, 2017 Yep they even give you 2.5 T+E clips to fix it! Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
