petrolhead Posted March 31, 2017 Posted March 31, 2017 App bersion will sms as well as push notification if it has a digi gprs. Quote
Mark Rider Posted March 31, 2017 Author Posted March 31, 2017 Ar ok so the app to work dont need WiFi or LAN can run off the GPRS as well ? You get full use of app with GPRS ? Quote
Simlec Posted March 31, 2017 Posted March 31, 2017 49 minutes ago, petrolhead said: App bersion will sms as well as push notification if it has a digi gprs. Can't say I have tried but in manual for gprs IMPORTANT NOTE: The DIGI-GPRS+SIM can only be used on HomeControl+ V2.0 and V2.1 control panels. Please see your control panel user, programming and installation manuals for further information. SMS functionality is not currently supported. Quote
Mark Rider Posted March 31, 2017 Author Posted March 31, 2017 I will email pyronix and ask. Also can't find anywhere that sell.the gprs module and the SIM . As i have herd pyronix do a sim. Quote
petrolhead Posted April 1, 2017 Posted April 1, 2017 It works on one i fitted a while back, not tried it since. Very early firmware one. Quote
Mark Rider Posted April 1, 2017 Author Posted April 1, 2017 Ok great. So you by the app version panel but you still need to by the goes module so why doesn't the panel come with the module and what's the difference with the app panel compared to the standard euro 46 panel as i thought you would of got the module with the app version and that was the difference but it isn't. Thanks Mark Quote
al-yeti Posted April 1, 2017 Posted April 1, 2017 (edited) 30 minutes ago, Mark Rider said: Ok great. So you by the app version panel but you still need to by the goes module so why doesn't the panel come with the module and what's the difference with the app panel compared to the standard euro 46 panel as i thought you would of got the module with the app version and that was the difference but it isn't. Thanks Mark Probably because there's only so many modules you can fit inside it, so why sell you something you dont need ,and make it optional Edited April 1, 2017 by al-yeti Quote
Simlec Posted April 1, 2017 Posted April 1, 2017 2 hours ago, petrolhead said: It works on one i fitted a while back, not tried it since. Very early firmware one. No you are correct, but it has to be a third party SIM card & not a CSL one. I have only installed the CSL ones. So there you go Mark, buy the app version panel and get the GPRS module with a high street data SIM card. Quote
Amps Posted April 1, 2017 Posted April 1, 2017 I've registered with the Pyronix Cloud as Administrator. Does registering as an installer give more options? Quote
al-yeti Posted April 1, 2017 Posted April 1, 2017 6 hours ago, Simlec said: No you are correct, but it has to be a third party SIM card & not a CSL one. I have only installed the CSL ones. So there you go Mark, buy the app version panel and get the GPRS module with a high street data SIM card. Does the gprs sim card come in the gprs card as a set? Quote
