Spherehopper Posted April 6, 2017 Posted April 6, 2017 I recently moved into a house with existing Scantronic 9752/9941 system and have flashed it back to factory, added some new PIRs and a GSM communicator (standalone box by ControlFreq) triggered by -ve from alarm output. I've set it all up and working fine (apart from the [national installer] Elmdene SAB that has a permanent tamper fault that I'm looking into). An alarm condition will SMS the phones I need it to but on my previous Texecom (Veritas and Premier), there was a RR input that I could pull down to 0v to acknowledge/silence the alarm remotely. How can I do this on the 9752? I have the ENG RESET (Prog 33) ON and REDCARE RESET (Prog 23) ON but as far as I can see the Redcare/Remote Reset application of 12v on the third pin up on the communicator connector only allows a user reset inside the house. Is there a way to -ve or +ve to one of the pins to do a full remote reset of the panel rather than just allowing an eng/user reset downgrade which means someone still needs to enter a code on the RKP? Thanks for your help! Quote
Spherehopper Posted April 6, 2017 Author Posted April 6, 2017 That is an option I guess, use one of the zones programmed as a momentary keyswitch to unset and connect my GSM relay output (responds to incoming call by toggling relay). Thank you. Quote
Spherehopper Posted April 6, 2017 Author Posted April 6, 2017 Edited to add, worked a treat, thank you. Zone 8 now set as mom keyswitch, relay in GSM module working perfectly to unset/set alarm. Quote
