dan100fast Posted April 8, 2017 Posted April 8, 2017 Hi, I have DIY fitted a Pyronix Enforcer, its all set up and all seam to work except from a call arc fail message I have studied and researched this and have been advised to disabled it ? I cant work out how to do this I cant find any logical method to stop this error message, every time I exit the engineer mode the error call arc fail appears ? Can anyone please help it driving me mad Regards Dan Quote
Lwillis Posted April 8, 2017 Posted April 8, 2017 Are you using any comms on the system? Sounds like you've got Arc/SMS enabled. Disable that and try again Quote
al-yeti Posted April 8, 2017 Posted April 8, 2017 As Mr Willis Just bashing , Have you entered details into the digi section to call arc? Some of those settings are not for speech / sms dialling if that makes sense Quote
dan100fast Posted April 8, 2017 Author Posted April 8, 2017 Hi thanks for help, it just has a wifi card and app set up can't seem to see any way to disable the arc unless its because I've putting settings in where not needed Quote
Lwillis Posted April 8, 2017 Posted April 8, 2017 Sounds like you've enabled something that you shouldn't have. Quote
dan100fast Posted April 9, 2017 Author Posted April 9, 2017 Thank you for the help, away for day or so but will try this soon as I'm back Quote
dan100fast Posted April 11, 2017 Author Posted April 11, 2017 Hi looked at the menu option and there is no options to program arc enable or disable ? I have been through all the menu options and instructions and cannot find anything in relation to disable the arc ? Quote
al-yeti Posted April 11, 2017 Posted April 11, 2017 1 hour ago, dan100fast said: Hi looked at the menu option and there is no options to program arc enable or disable ? I have been through all the menu options and instructions and cannot find anything in relation to disable the arc ? So what page of the manual did you read if you can't find it through the menus , i don't use this panel , but it wasn't hard to find in manual Look at manual and follow menus Quote
dan100fast Posted April 12, 2017 Author Posted April 12, 2017 All Sorted It turns out that the Enforcer models are different between the normal model and the app version hence the different manual options mentioned and why I could not find an arc disable option It turns out that I had entered our phone numbers in the SMS menu thinking this was part of the set up, once removed it worked perfect ! as it has the app function no numbers are required in the SMS setup which also seems to set up the arc Thanks to Mr Willis who called me today to offer his help Really nice to have the offer of help without the pound signs Quote
