dannygd83 Posted April 10, 2017 Posted April 10, 2017 Hi, I asked last week what would be the best dialler to connect to my existing system and was advised on a honeywell informa. After purchasing this and looking at the connections, I understand the dialler needs 4 cable from the panel and two are power, it's just the other two. Any help would be great. Thanks in advance Quote
Spherehopper Posted April 14, 2017 Posted April 14, 2017 On 10/04/2017 at 2:14 PM, dannygd83 said: Hi, I asked last week what would be the best dialler to connect to my existing system and was advised on a honeywell informa. After purchasing this and looking at the connections, I understand the dialler needs 4 cable from the panel and two are power, it's just the other two. Any help would be great. Thanks in advance Are you sure there are only 4 cables to connect inc the power? The manual is available online that shows the connections. Quote
al-yeti Posted April 14, 2017 Posted April 14, 2017 On 10/04/2017 at 2:14 PM, dannygd83 said: Hi, I asked last week what would be the best dialler to connect to my existing system and was advised on a honeywell informa. After purchasing this and looking at the connections, I understand the dialler needs 4 cable from the panel and two are power, it's just the other two. Any help would be great. Thanks in advance Two for power Two for the telephone line in Two for telephone out if your going the whole hog One or more for the trigger , standard to use one trigger intruder and others if you have smokes or pa button and so on Quote
