Hi, I asked last week what would be the best dialler to connect to my existing system and was advised on a honeywell informa. After purchasing this and looking at the connections, I understand the dialler needs 4 cable from the panel and two are power, it's just the other two. Any help would be great. Thanks in advance
Are you sure there are only 4 cables to connect inc the power? The manual is available online that shows the connections.
Two for power
Two for the telephone line in
Two for telephone out if your going the whole hog
One or more for the trigger , standard to use one trigger intruder and others if you have smokes or pa button and so on
