dannygd83 Posted April 10, 2017 Posted April 10, 2017 Hi, I asked last week what would be the best dialler to connect to my existing system and was advised on a honeywell informa. After purchasing this and looking at the connections, I understand the dialler needs 4 cable from the panel and two are power, it's just the other two. Any help would be great. Thanks in advance Quote
black knight Posted April 10, 2017 Posted April 10, 2017 Not too familiar with this particular type but there will be permanent power ( 12volts from / to + - ) and a connection to make the autodialler start usually a switched - . This can be either connected to bell output on panel or to digi ch3 / intruder output if you have one . Depending on the autodialler you can use other channels for fire , PA , medical etc if you have appropriate outputs on panel . There may also be a tamper connection on auto dialler that connect in usual method to your panel Hope that helps Quote THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
al-yeti Posted April 10, 2017 Posted April 10, 2017 (edited) Just connect ip1 to the bell trigger for now and Neg and pos to -ve and +ve Edited April 10, 2017 by al-yeti Quote
dannygd83 Posted April 10, 2017 Author Posted April 10, 2017 Thanks again for your help with this, I understand the dialler needs power it's just the other pair from IN1 and INH on the dailer, thanks Quote
al-yeti Posted April 10, 2017 Posted April 10, 2017 Forget inh for now , ip1 to neg bell trigger Quote
dannygd83 Posted April 10, 2017 Author Posted April 10, 2017 Thanks but when I tried that it just keeps dialling Quote
al-yeti Posted April 10, 2017 Posted April 10, 2017 You need to change the polarity possibly triggers On the dialler Quote
dannygd83 Posted April 10, 2017 Author Posted April 10, 2017 I don't understand that as I only have 1 cable connected apart from the power pair Quote
sixwheeledbeast Posted April 11, 2017 Posted April 11, 2017 Trigger pins work on logic level. So say a negative or positive, removed or applied to the pin. It's this boolean logic that triggers the equipment. So if your dialler is triggering over and over it's most likely being held in the inverse state. In bashing terms, invert the panel output or invert the trigger logic. Also note that dialler maybe dialling over and over because you are not acknowledging the call. I would assume the thing came with a manual, have a cuppa and read over it carefully. Quote
al-yeti Posted April 11, 2017 Posted April 11, 2017 So in manual look at setting trigger levels (4) Then acknowledge the call by pressing * i think , that will stop it calling And yes that's correct apart from power , the other wire (cable as you put it) can be connected to the bell trigger or a pgm , programmable output , and it's trigger as explained by swb Quote
