sharkey Posted April 11, 2017 Posted April 11, 2017 Hi AllI have two Hikvision NVRs each has a HDMi & Lan output and I wish to view both NVrs on one HDTV, however I want it to auto switch between the two sources.any ideas? Quote
al-yeti Posted April 11, 2017 Posted April 11, 2017 Lan output? You intend to decode? Auto switch instead of manual hdmi switcher? Auto in what way I not the expert lol just copy what terms others use lol 1 Quote
sixwheeledbeast Posted April 11, 2017 Posted April 11, 2017 What is the application? Switching between sources would be annoying for the viewer. Any reason for not using one NVR or two monitors? Quote
sharkey Posted April 11, 2017 Author Posted April 11, 2017 I have two 4 way NVRs one is a IP cam system & one is a Analogue system, the units both have HDMI output and I want this to switch between the quad display on both NVRs on the one monitor. Quote
petrolhead Posted April 11, 2017 Posted April 11, 2017 But auto in what way? What would trigger the switch? Quote
sharkey Posted April 12, 2017 Author Posted April 12, 2017 9 hours ago, petrolhead said: But auto in what way? What would trigger the switch? Hence the question. Quote
sharkey Posted April 12, 2017 Author Posted April 12, 2017 1 minute ago, sharkey said: Hence the question. I am looking for a solution to this or an alternative. Thanks Quote
al-yeti Posted April 12, 2017 Posted April 12, 2017 so in plain brexit language Your looking for a hdmi switcher with some kind of remote switch , which could be triggered by a remote etc Quote
sharkey Posted April 12, 2017 Author Posted April 12, 2017 Basically yes, or any other way of getting two NVRs onto one monitor, switching. Quote
al-yeti Posted April 12, 2017 Posted April 12, 2017 23 minutes ago, sharkey said: Basically yes, or any other way of getting two NVRs onto one monitor, switching. Yes but any other way is just using a hdmi switch You specifically want to trigger it sitting on your sofa yeah? Quote
