Hi All
I have two Hikvision NVRs each has a HDMi & Lan output and I wish to view both NVrs on one HDTV, however I want it to auto switch between the two sources.
any ideas?
Lan output? You intend to decode?
Auto switch instead of manual hdmi switcher? Auto in what way
I not the expert lol just copy what terms others use lol
  • Upvote 1
I have two 4 way NVRs one is a IP cam system & one is a Analogue system, the units both have HDMI output and I want this to switch between the quad display on both NVRs on the one monitor.
so in plain brexit language
Your looking for a hdmi switcher with some kind of remote switch , which could be triggered by a remote etc
23 minutes ago, sharkey said:
Basically yes, or any other way of getting two NVRs onto one monitor, switching.
Yes but any other way is just using a hdmi switch
You specifically want to trigger it sitting on your sofa yeah?
