powered contacts & pa button ?
2 minutes ago, PeterJames said:
Link it out at the detector, if it still keeps going off then its either the panel or the cable, if it stops then its the ultrasonic
this the easiest way to DIY fault find,
normally you take & record resistant readings of each circuit,
I already knew this but the op didnt
Just now, PeterJames said:
What voltage did you get at the pa button?
It came up as 12.3v
Thank you
