Gents,
Thank you for your replies. I am fairly competent but have no idea what you mean by a shaved monkey or a house basher?
Peter, how do you default the codes in order to deprogram it or is Google my friend?
12 hours ago, Juiceloose said:
Gents,
Sorry we cannot give defaulting info here, but it is in the manual
LOL about Shaved monkeys and House Bashers
One of the same
Not sure the information is in the manual unless you already have the engineer code.
As above we cannot give out defaulting information here.
Get new panel change engineer code to something complicated , immediately lock panel leave it for four weeks and see if you can still do it
That is the hub of the problem......I don't have an engineer code so looking like a new panel. I'm guessing when I remove the cover off the current one it's going to be a tad noisy. I guess it's a disconnect at mains and disconnect back up battery to silence it then install the replacement panel and back up battery into it then try and program it.
1 minute ago, james.wilson said:
what you on about al?
I was wondering that too :-)
