Posted (edited)
See attached i have an old KEYPAD on a Gardtec 595 Panel the screen has went, i have tried to swap it out with this new 4 Wire Blue LCD Keypad however it does not work does anyone know a way of getting it to work with resistors or do i need to send this back to Risco Group and get a 6 Wire Version?
If i need to send back and get a 6 Wire Version does anyone know if it is available in Blue LCD?
Thanks Jack Buchan
JDB Solutions
Edited by james.wilson
no contact detail in post
According to the manual page you've photographed, it should be fine...
I'm guessing you've done a panel cold start?
First down power the panel and switch back on to see if the blue LCD keypad goes through its startup.
If you are getting the same you get the 6 wire keypads but they are not blue LCD.
23 hours ago, james.wilson said:
jack i thought you were going into tow bars?
iirc the old 6 wire is dead, there may be some old sh## around
Hi James yes we do fit thousands of Towbars Did you remember me ?
12 hours ago, PeterJames said:
you can still get 6 wire not sure if they are blue or not
Ok thanks
Ok il try this although Risco told me it won't be compatible
Depends I think, on my old one the socket was out of sight. I hate seeing towbars or the gubbins of them.
