What the difference between the following:
  • EURO 064 - LCD Keypad with proximity reader, 2 inputs and 1 output
  • EURO 068 - LCD Keypad with proximity reader
  • EURO 069 - LCD Keypad
Which one should I use with my Pyronix Enforcer wireless alarm system. i plan to wire the keypad to the control panel.
I Normally for the 064 didn't think they did the other ones anymore
there used to be a NON Prox version for the Euro mini .
25 minutes ago, james.wilson said:
so the enforcer has a data bus?
Indeed, you can connect all the wired stuff too.
So basically you can connect any of them , if you can find the 064 that is
I have used the 64 from the enforcer data and hard wire the front door, entry PIR and the speaker to the keypad.
1 hour ago, al-yeti said:
If keypad fails what then? Meaning if 64 not available
Same as other brands with zones on keypad, saves on time and cabling.
