Sirtoddius Posted May 4, 2017 Posted May 4, 2017 Look closely at this photo. Can you spot the obvious error. Yes that's correct. They have not cut one of the cable ties. :-/ other than that it seems like a immaculate installation. Quote
Sirtoddius Posted May 4, 2017 Author Posted May 4, 2017 7 minutes ago, al-yeti said: Your on crack yes? Only at the weekends. There is a hint of sarcasm in my post. Quote
MrHappy Posted May 4, 2017 Posted May 4, 2017 Are both intruder & cctv done by the same mongs ? 1 Quote Mr Veritas God
petercts Posted May 4, 2017 Posted May 4, 2017 Is the sounder on with more than one screw or fixed with cable clips if so its a proper job or maybe no more nails and the local cable rules state staple guns and washing lines are also up to the standard of an approved installer 1 Quote
Rulland Posted May 4, 2017 Posted May 4, 2017 The intruder/CCTV installers obviously didn't take heed of the warning sign 1 Quote
datadiffusion Posted May 4, 2017 Posted May 4, 2017 3 hours ago, al-yeti said: Your on crack yes? You wish you were! Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
PeterJames Posted May 4, 2017 Posted May 4, 2017 34 minutes ago, petercts said: are you sure the approved installer can read Who said it was installed by an approved installer? Quote
