shaun c Posted May 14, 2017 Posted May 14, 2017 Hi Guys I've just registered as a new member. Security engineer for 15 years or so. I have juts purchased a Pyronix Enforcer Wi-Fi V10 to have a play. Has anyone used or managed to use the remote software for the PC to allow remote diagnostics etc.? Ive downloaded it from Pyronix but seems as this does support the Enforcer Panel? Any help would be appreciated Thanks Shaun Quote
Simlec Posted May 14, 2017 Posted May 14, 2017 (Have not tried it with V10 but should be no different) The Enforcer works fine with remote software InSite UK. Are your PC & panel on the same network? could be the problem. Have you got the cloud & IP indicators green at the bottom of software? Quote
shaun c Posted May 14, 2017 Author Posted May 14, 2017 Hi thanks for your reply. Ive not really played with it that much as yet but when i looked one of the drop down boxes for panel type nothing was listed enforcer?! Quote
james.wilson Posted May 15, 2017 Posted May 15, 2017 I think its a euro meridian under the skin Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
shaun c Posted May 15, 2017 Author Posted May 15, 2017 James will look at it again just wondered if any one else had found it a little confusing to work on! Quote
al-yeti Posted May 15, 2017 Posted May 15, 2017 3 hours ago, shaun c said: James will look at it again just wondered if any one else had found it a little confusing to work on! They are Real alarm men , unlikely Quote
jiml Posted May 15, 2017 Posted May 15, 2017 PM me your email address and I will send you access to our training videos. There's I full details on how to setup Insite with v10 enforcer. Tip. Use roving dual then Insite works out the panel type. Quote
