druid Posted May 14, 2017 Posted May 14, 2017 I manage three separate Domonial installations and have done so for at least five years. I've found it straightforward to program, whether using a TCU or DOMO-PC. On each installation, either a keycode or a tag can be set up for arming and disarming. I recently replaced one of my existing CMI8UK-STD-5 panels (K13) with a CME8UK-STD-7G (L12) as I needed to add extra smoke sensors. The upgrade also required replacing several sensors and the keypad - the old CSK88HF-B keypad was replaced with a LKP-S8M-PWA and a TCU. On the new installation, keycodes do not appear to work correctly. A keycode can be used to arm the system, and during the pre-arm bleeps, a keycode can be used to disarm it. However, on re-entry to the premises, or once an alarm has been triggered, a keycode will not disarm the system. Tags work fine. I can find no setting which could cause keycodes to behave in such a peculiar way. Can anyone tell me what I'm doing wrong? Mark Quote
Monty Posted May 14, 2017 Posted May 14, 2017 Sounds like it's set up to lock the key pad out on entry will prob let you use a code to unset once entry timer has run out if this is the case just have to find the setting in DD243 Quote www.AllanMoncrieffAlarms.com
al-yeti Posted May 14, 2017 Posted May 14, 2017 Does is have a bs section for menu , tag on entry , restricted in entry , and all the compliance stuff Many panels have it so be surprised if that doesn't I have no idea about those panels , perhaps all the older versions were not set as default restricted in entry but new ones all seemed to be default tag on entry , atleast the Honeywell and Hkc panels are , I think lol Just now, Monty said: Sounds like it's set up to lock the key pad out on entry will prob let you use a code to unset once entry timer has run out if this is the case just have to find the setting in DD243 Ah that's what I like less house bashing terminology lol more pro Quote
druid Posted May 15, 2017 Author Posted May 15, 2017 Thank you for your suggestions, guys. The only configurations that I can find related to tags is in the User Settings. There is an "Arming with code" checkbox, which I would guess is the reason that I can use a code to arm it. In addition, each user profile has both "Tag" and "Registered Tag" checkboxes. The first allows that profile to support a tag, whilst the second indicates whether a tag has been registered in that profile. However I can find no other tag-related settings, or restrictions on entry. Is it really possible that the new Domonial panels only support disarming by tag? Mark Quote
