Search1231 Posted May 16, 2017 Author Posted May 16, 2017 thanks for your responses, what beams would you reccomend Quote
MrHappy Posted May 16, 2017 Posted May 16, 2017 7 minutes ago, Search1231 said: thanks for your responses, what beams would you reccomend if the building is open to the elements, wired external beams, which probably means your ebay stuff needs relocating to a skip you also should be looking to contact all the doors any wiring needs to be protected for the birds Quote Mr Veritas God
Search1231 Posted May 16, 2017 Author Posted May 16, 2017 pic of the alarm panel, it has 8 wired zones, just a question about beams, i have around a 1-2ft section of void across majority of the roof, the cages are below, the metal roof is above, if i am using beams which are say 20cm high, am i right in thinking the beams will travel within that 20cm height, if the beams had say a 50cm height, then the beam would travel through a cage and will get triggered, i could do with some clarity on this please. Quote
norman Posted May 16, 2017 Posted May 16, 2017 This looks like the stuff Peter James imports/supports, he'll be along shortly... 1 1 Quote Nothing is foolproof to a sufficiently talented fool.
MrHappy Posted May 16, 2017 Posted May 16, 2017 2 hours ago, Search1231 said: pic of the alarm panel, pic of where it should be fitted.... 1 Quote Mr Veritas God
sixwheeledbeast Posted May 16, 2017 Posted May 16, 2017 Optex or Takex for beams. You will need a proper alarm system to connect it too. As with a lot of electronic products on ebay, buy cheap buy twice. I would suggest you give a few local companies a call to see if you can get a good quote for a fitted system. Quote
james.wilson Posted May 16, 2017 Posted May 16, 2017 an active beam is a point to point device so needs very little room. think of a James bond stylee laser beam, break the beam and the receiver activates Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted May 16, 2017 Posted May 16, 2017 5 hours ago, Search1231 said: pic of the alarm panel, it has 8 wired zones, just a question about beams, i have around a 1-2ft section of void across majority of the roof, the cages are below, the metal roof is above, if i am using beams which are say 20cm high, am i right in thinking the beams will travel within that 20cm height, if the beams had say a 50cm height, then the beam would travel through a cage and will get triggered, i could do with some clarity on this please. All about budget now, I am sure everyone appreciates you may not be able to get something good installed , but you will go in circles I am sure the birds cost a bit and better you save up , do it once so you don't have to mess around Have you got a budget ? £1200? Quote
PeterJames Posted May 16, 2017 Posted May 16, 2017 Can the pet get within six foot of the detector, I guess so its a bird. 6 hours ago, norman said: This looks like the stuff Peter James imports/supports, he'll be along shortly... Your not funny, I am selective with my imports, I dont import anything thats likely to spontaneously com-bust. Quote
