declan Posted May 17, 2017 Author Posted May 17, 2017 12 hours ago, sixwheeledbeast said: http://www.thesecurityinstaller.co.uk/community/files/file/49-accenta-optima-gen-4-user-manual/ Hi I can still not download the g2 file, it gives and error code and says I am not allowed. I am logged in as myself. Do you know how to resolve this. Just now, al-yeti said: Well the compact was the same as the late accenta 8 as far as I know and you must have a duff panel The panel works fine as do all the keys. I need the correct user instructions for it, is all. Quote
al-yeti Posted May 17, 2017 Posted May 17, 2017 Don't know but this is same user manual https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.responseelectronics.com/downloads/1364919901Optima_G4_Panel.pdf&ved=0ahUKEwjoz87w7fbTAhWGBsAKHdA2Bf8QFggdMAA&usg=AFQjCNH-dThvAV2k98y5HqpP-ImVP2oNCg&sig2=JSWwiWuK5aOUF444kVrq-Q Quote
declan Posted May 19, 2017 Author Posted May 19, 2017 I figured it out, using bits of the manual instructions. Thanks for your efforts. Quote
OMPughy Posted August 22, 2018 Posted August 22, 2018 On 19/05/2017 at 17:39, declan said: I figured it out, using bits of the manual instructions. Thanks for your efforts. Hi Declan, I'm searching in exactly the same way you did! I have the exact same ADE Optima Compact alarm, same panel. I have the 4-digit code but no real idea what I'm doing. The only information I could find is this link - https://www.tlc-direct.co.uk/Technical/DataSheets/Ade/ACCENTA6_8_User.pdf Is this what helped you in the end or do you have another link? Thanks in advance Quote
