I recently replaced the dead battery in my Cooper Menvier 9651 alarm and whilst trying to clear the fault codes I stupidly reset all the commands to default and therefore now need to reprogram it from scratch.  I have the installers guide and tried my best setting it up with this but cant seem to get it up and running.  There's only one door contact and 5 PIR in the system which I have set as  'Final Exit (FE)' for the door and 'Normal Alarm (NA)' for the PIRs, the last two zones are set as 'Not Used'. But whenever I try to arm it, there's not a count down sound to exit and the unit just cycles through the zones and doesnt actually arm.  I may resort in getting some professional in to set it up, but I was wondering if anyone can provide some guidance in case I have missed something.
Thanks
It thinks all the zones are 'open'. Have you blown a fuse? Are the PIR LEDs lighting?
I assume all tampers are OK which is how you've managed to exit engineer mode, otherwise I was going to suggest checking Option 21 in the Eng menu...
Posted (edited)
10 minutes ago, sixwheeledbeast said:
I would say it's programmed for the incorrect wiring type myself.
I thought that, but then it would refuse to exit eng though?
OP - send us a picture of the alarm PCB as-wired, or, open up a PIR (any one) and show us the wiring.
Edited by datadiffusion
Posted (edited)
Hi photos of the pcb wiring uploaded. The PIRs seem to be working as they light up when someone is in the rooms.
Edited by kungfuman
Posted (edited)
OK; so it appears that it has been wired for 'global tamper'. Which is a shame, as this is a capable panel and doesn't need to be used in this 1980s way.
But I digress.
In engineer mode, what does option 21 say? Just go into engineer, press 2 1 and Enter (Tick)
It will either say ' FSL' or 'CC + Tamp' or similar
3 minutes ago, james.wilson said:
looks to me like its wired double pole and I assume that's default
It was - it changed at some point hence a Cooper Bulletin about it catching out the sparkies who didn't get why they couldn't exit eng without tampers!
However, either way I can't work out how the OP was able to exit eng mode (or, at least without a tamper alarm within seconds) if the wrong wiring was chosen...
Try linking the tamper circuit , close everything up and see if it starts to arm
