kungfuman Posted May 20, 2017 Author Posted May 20, 2017 1 hour ago, james.wilson said: well id be looking to prove the panel, looping out the circuits. I suppose you could have a voltage on a leg. You didn't connect the battery the wrong way round did you? Nope, double checked and battery went in the same connections as the old one. 1 hour ago, al-yeti said: Try linking the tamper circuit , close everything up and see if it starts to arm How do i go about linking the tamper circuit? When i remove the unit cover, the tamper internal alarm does sound and i have to punch in the code to stop it. Quote
al-yeti Posted May 20, 2017 Posted May 20, 2017 Put a loop on global tamper , and as jw said loop out every circuit to see if anything changes , then add each zone circuit back one at a time Quote
datadiffusion Posted May 20, 2017 Posted May 20, 2017 I would hazard the tamper is fine if the panel is not in alarm all the time?? As before, with a tamper, you wouldn't even be able to exit eng... It won't hurt to do it though. Going back to basics, what happens when you do a walk test, OP? (Eng Command 97) Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
