Have a look at this I created https://github.com/dklemm/FlexSIA2MQTT.  It might even do what you want, if not it should still help you work out how to ACK the alarm messages.
I had plans to create a HomeAssistant auto discovery component and commands api (set/arm etc),  I have a poc of this just not looked at it for a while.
Much of this was reverse engineered from https://github.com/mkontsek/openGalaxy.
18 minutes ago, james.wilson said:
Is this something your running on HA?
Not directly on "HA"  but integrated via an MQTT broker and using the various MQTT components in HA to pick up events e.g. door sensors from mag contact and movement sensors from PIRs
  • 1 month later...
 Hi, I own a FX100 panel and I would like to pick up status of mag contact movements sensors like you mentionned.
Can you tell me briefly how to integrated the FlewSIA2MQTT via an MQTT broker ? Which MQTT broker do you use ?
Thank you very much for your help
  • 1 year later...
