Gillmstar Posted May 30, 2017 Posted May 30, 2017 Hey guys an gals! I'm a security installer in the north west, having some trouble with the lightsys panel and the fire alarm aspect, using an apollo smoke, end of line, the zone is programmed as a "fire" and is not in tamper, yet when I trigger it it isn't triggering the alarm, I thought this is wired correctly but it mustn't be? It has got power and lights up but doesn't trigger the alarm. any help would be massively appreciated! Thanks people. Quote
Gillmstar Posted May 30, 2017 Author Posted May 30, 2017 One is with the green cable which is in the first terminal on the left, the next one is the two resistors in the one terminal next to that but with no cable, and the last leg of the resistor is just soldered to the white cable that heads back to the panel, hope this makes sense, made up to have some help on it thanks Quote
al-yeti Posted May 30, 2017 Posted May 30, 2017 Does it make a difference if you power is connected to out and not in? Quote
Gillmstar Posted May 30, 2017 Author Posted May 30, 2017 Haven't tried that, do you think that would potentially make it work? I'm back there tomorrow so hoping to have more of an idea to get it sorted then Quote
al-yeti Posted May 30, 2017 Posted May 30, 2017 Personally , I am a professional house basher , so I got mad lab setup at home and try everything before going out I havnt used these , but I guessing I prefer the texecom version , more striaghten forward Regarding the terminal if it's just short then no , if there's electronics involved then maybe What about the jumpers have you set them right? Quote
sixwheeledbeast Posted May 30, 2017 Posted May 30, 2017 So logical first thing to do is check if the issue is the device, wiring or programming and work from there. Jumper is Latch or Non-latch Quote
