miaren Posted May 30, 2017 Posted May 30, 2017 Anybody else suffering with Dahua IP Cameras rebooting very repeatedly...? Currently trying to configure one for a Job, and noticed repeated rebooting. Initially replaced the PSU, then tried POE but still occuring... Checked 2 other cameras that have been working well for many months and noticed both started a similar pattern this morning.. Logs show Abort, Startup then Hot Swap...in that order. My initial thought was a dodgy SD Card, but not all have Edge recording Bit confused as to whats going on and what has caused it to occur...? Quote
9651 Posted May 30, 2017 Posted May 30, 2017 Not got any issues as yet, got quite a few out there now infact we are finishing off a 60 cam install at the mo, no issues as yet mixture of wedge cams and bullets Quote
miaren Posted May 30, 2017 Author Posted May 30, 2017 Tried defaulting the new camera and one of the original cameras and the issue is still occuring...? Quote
9651 Posted May 30, 2017 Posted May 30, 2017 These must be conflicts or something? Unplug and try one at a time? Quote
miaren Posted May 30, 2017 Author Posted May 30, 2017 It does appear to be some sort of conflict... When not connected to router, seems to be more stable and doesnt want to reboot.. I should have explained the cameras mentioned were on a separate site 8 miles away Quote
miaren Posted May 31, 2017 Author Posted May 31, 2017 Checked the switch range - all ok, but now sorted with a Firmware Update.... Very interesting that 2 cameras that were working well, went wrong on the same day... Quote
