Azzer2005 Posted June 5, 2017 Posted June 5, 2017 Hello all, I've got OP1 configured to activate on alarm for a soundbomb in an outbuilding. I want the output to de activate after 10 minutes or until the user code is entered. Ive set the pulse timer 3 to 10 minutes and added the pulse timer 3 attribute to the output settings. Do I need to add the latching attribute to make the output de activate upon code entry or will it do that by default with the pulse timer attribute? Thanks in in advance for your help! Aaron Quote
Azzer2005 Posted June 5, 2017 Author Posted June 5, 2017 Just had another skim through the manual, I beleive I can acheive the above by scrapping the above and simply setting the output group to area 28 - Bell SAB? Quote
