49 minutes ago, datadiffusion said:
With the zone splits, wasn't there a 'B' terminal in Abacus brand PIRs for a 2nd circuit (but shared tamper??), or couldn't you use a splitter box? And wasn't the split thing just glorified EOL using unpublished values?
Just wondering if that, as well as a ropey contact/connection could be an issue...
You had to use a zone splitter to split zones, its programmed as a final exit on part set, so when part set it should start up the entry timer before going into alarm, if you part set the alarm.
Have a couple of things to look at in the short term then.
In the long term think it's Abacus RIP time and will replace with a modern unit but will start anew topic on that.
Thanks for your replies.
Although abacus RIP won't necessarily solve your problem......
QFA the Ab is a good panel, and the fault is not the panel
He meant you...
9 minutes ago, PeterJames said:
I still have a fair few out there going strong
13 minutes ago, james.wilson said:
it was but its an oap now
