Hoping someone here can help me!
Roughly 12 months ago I had our existing alarm replaced with the EURO 46, all has been fine until last week.
The white metal box (control panel?) started making a low buzzing noise, but all continued to function ok.
Couple of days ago the keypad started warning that the battery in the control panel wasn't charging, then battery critical, now its saying low volts, at this point the buzzing has stopped!
I'm struggling to find someone to come take a look.
Any ideas?
warranty ?
50 quid says either existing battery re-used, new from Maplins, or just a 2nd hand battery which has failed nearly taking PSU with it.
27 minutes ago, MrHappy said:
warranty ?
Possibly on the hardware, the install was a cash job, the relationship has since soured.
You think a straight replacement battery will solve the problems?  Surly I can do this myself?
17 minutes ago, norman said:
Do you have a smoke alarm nearby?
I have a nest protect smoke alarm
approx 8ft away.
OK; do you have the engineer code?
Posted (edited)
Yes, I have the engineer code :o)
Edited by POC
place into eng,
open lid remove battery lead
if system remains powered try a replacement battery
if not its fuse /transformer ect...
34 minutes ago, MrHappy said:
place into eng,
Great thanks, do you know what battery I'll need?
I assume 7ah, buy a quality make like Genesis or Yuasa, avoid Chinese no-name or 'Lucas' ones from eBay.
