Posted (edited)
Hi Guys & Girls
Finally got Miniair set up after some trial and error, found a solution to the  keyswitch as CSL did not know. I told CSL how I done it buy using Bentley Toggle Relay to a Keyswitch Zone. they went and placed order next day, I got a nice thank you from Bentleys.
Only issue now is I'm sending Contact ID to ARC  however the ARC software is automatically handling the alarm as it's seeing the Zone Restoral. Is there away to stop the Zone Restoral ? I've looked manual high low can't find it, can only see mention for send restores after reset for Fast Format.
TIA, Joe
Edited by Joe Doherty
  On 15/07/2017 at 15:51, MrHappy said:
don't use it....
Can't you define what content is sent ? & whether it restores ?
Expand
You can but cant disable restores on a G2.
Ask EMCS to setup the restores as non filtering and to abort on Open.
Expand
Or install a dimension
