Muttsnutts Posted July 19, 2017 Author Posted July 19, 2017 3 hours ago, norman said: Is that PCB in the case upside down? No I don't think so, and I think it is the micro x line from looking at PDF online. Quote
norman Posted July 19, 2017 Posted July 19, 2017 How do you get the screw in when it's adjacent the ceiling? Quote Nothing is foolproof to a sufficiently talented fool.
Muttsnutts Posted July 19, 2017 Author Posted July 19, 2017 Remove the small screw on the pcb and pull board away and fix the the rear of the housing to the surface and re attatch Quote
al-yeti Posted July 19, 2017 Posted July 19, 2017 13 minutes ago, Muttsnutts said: No I don't think so, and I think it is the micro x line from looking at PDF online. So you know the model all sorted Quote
Muttsnutts Posted July 19, 2017 Author Posted July 19, 2017 2 minutes ago, al-yeti said: So you know the model all sorted Yep all for the help. Quote
MrHappy Posted July 19, 2017 Posted July 19, 2017 7 hours ago, Muttsnutts said: looks a pile of poop... replace with an dt8016 or an Iwise DT, the toolstation pir is tat Quote Mr Veritas God
norman Posted July 19, 2017 Posted July 19, 2017 (edited) 1 hour ago, Muttsnutts said: Remove the small screw on the pcb and pull board away and fix the the rear of the housing to the surface and re attatch No, the casing screw (hole) shown @ the top of the photo. Edited July 19, 2017 by norman Quote Nothing is foolproof to a sufficiently talented fool.
Muttsnutts Posted July 19, 2017 Author Posted July 19, 2017 1 hour ago, norman said: No, the casing screw (hole) shown @ the top of the photo. Umm it's the small phillips one just to the left of the red led ? Quote
james.wilson Posted July 19, 2017 Posted July 19, 2017 no the lid screw, not the pcb screw Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Muttsnutts Posted July 19, 2017 Author Posted July 19, 2017 You Deffo have to remove the small pcb screw to fit it to a wall. Installation Instructions 1. Open the housing by removing the front cover. To do so, press the tab located on top of the detector. 2. Remove the PCB by unscrewing the PCB screw from the rear of the protective plastic casing. Note: Do not touch the face of the PYRO sensor. Quote
