Not a bad little device, I did some testing and evaluation on it for CSL last month.
Signalling works fine, quite a fast device, Although the IPhone app needed a little tweaking but I'm assuming this would be sorted by now.. Got it setup and controlled by iPhone working on remote set/ unset for all Texecom panels, including veritas.  I can see a market for it.
Just now, james.wilson said:
is that via the relay pse?
Yes mate, A basic SPST for the Premier/ Elite range and a SPST with 0v trigger input for Veritas
Both panels need a few options changing
Even if your just using the app side the arc still have to do the hosting and accounts side
This means there is two prices
1 same as the digiair price ish!  but just slightly cheaper - ARC deals with Keyholders
2 hosting only so just to the app - alot cheaper - No actions from ARC at all!
got a demo unit working fine with just 12v 0v and N/O trigger connected
you dont have to use the keyswitch input
so a straight 3 wire connection at basic level
the contact id dial capture is good through the app - up grade for me at home!
set up and program on the Installers app - MiniAir
then customer logs in and set up notifications for them on there app - My Home Alarm
might get time later do a video and add link
  • 4 weeks later...
  • 6 months later...
