ThornGamma6 Posted July 20, 2017 Posted July 20, 2017 Hi, I'm having Issues with my Accenta G4 and all its doing is the RKP is just displaying Accent G4 RKP F131-01-111 I have 6 zones in use and all pirs are the Pyronix Equinox pirs and 1 of them is above the keypad in the corner of my hallway by the front door. would it be the PIR causing the fault? Quote
datadiffusion Posted July 20, 2017 Posted July 20, 2017 AFAIK the LCD keypad can only translate 'LED data' from the system into locally defined messages. So if the keypad is showing what I would assume is the 'default screen' it suggests the data connection to the panel has been lost, just the power remaining, or the panel is goosed other than the PSU. Have you tried turning it off and on again? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
al-yeti Posted July 20, 2017 Posted July 20, 2017 1 hour ago, ThornGamma6 said: Hi, I'm having Issues with my Accenta G4 and all its doing is the RKP is just displaying Accent G4 RKP F131-01-111 I have 6 zones in use and all pirs are the Pyronix Equinox pirs and 1 of them is above the keypad in the corner of my hallway by the front door. would it be the PIR causing the fault? Have you replaced the keypad recently Quote
ThornGamma6 Posted July 20, 2017 Author Posted July 20, 2017 1 hour ago, al-yeti said: Have you replaced the keypad recently Tbh Its second hand and the panel says Accenta 8 mini on the front 1 hour ago, datadiffusion said: AFAIK the LCD keypad can only translate 'LED data' from the system into locally defined messages. So if the keypad is showing what I would assume is the 'default screen' it suggests the data connection to the panel has been lost, just the power remaining, or the panel is goosed other than the PSU. Have you tried turning it off and on again? I've tried turning it off and on again but doesn't seem to be working Quote
MrHappy Posted July 20, 2017 Posted July 20, 2017 put the rkp onto a foot long "flylead of cable" & see if it works... Quote Mr Veritas God
ThornGamma6 Posted July 20, 2017 Author Posted July 20, 2017 It does have 1ft long cable going to the panel and it doesn't work mate. This system was removed from a building that was getting demolished and I got first dips into the alarms I even saved to Pyronix Deltabells Quote
MrHappy Posted July 20, 2017 Posted July 20, 2017 you've tested the cable between controls & rkp ? Quote Mr Veritas God
datadiffusion Posted July 20, 2017 Posted July 20, 2017 (edited) 16 minutes ago, ThornGamma6 said: It does have 1ft long cable going to the panel and it doesn't work mate. This system was removed from a building that was getting demolished and I got first dips into the alarms I even saved to Pyronix Deltabells Historic England won't thank you though; next time just go for the copper, and spend 1/3 of the payout on a Vanderbilt SPC. Trust me. Edited July 20, 2017 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
ThornGamma6 Posted July 20, 2017 Author Posted July 20, 2017 36 minutes ago, MrHappy said: you've tested the cable between controls & rkp ? Yes mate I have 27 minutes ago, datadiffusion said: Historic England won't thank you though; next time just go for the copper, and spend 1/3 of the payout on a Vanderbilt SPC. Trust me. I got a bit of copper which I'm going to sell for scrap Quote
