35 minutes ago, John Charnock said:
BTW - I am not planning on doing this install myself, I am just acquiring knowledge so I know what to look for with a supplier.
I have completed two online inquiry forms for two reputable local suppliers recently and neither of them has contacted me, the alarm business must be booming.
J
If you mentioned what you wanted in the online enquiry then its unlikely that you will be contacted. Perimeter external security would not be popular amongst your average house basher, especially if you drop in words like solar powered, two words that would set any self respecting installer running in the opposite direction. There are various solutions out there, we installed a system at a house in Weighbridge recently for circa £45k using similar to this http://www.southwestmicrowave.com/products/buried-cable-detection-systems/ but I would guess its a bit out of your budget.
3 minutes ago, John Charnock said:
I am looking for a layered approach.
That's fine, security is better in layers not many think about this. You will already have some layers I imagine; unless you leave your doors and windows open.
Perimeter systems are generally suited to large detached properties where someone is in close proximity to site and immediately action.
We have no idea on the property or what you expect from this perimeter protection system, or what the risk of the property and it's contents is.
I also agree it's unlikely you would here back from an online enquiry for this type of work.
Yes, I already have an internal alarm system.
I may end up doing it myself (;-)
CCTV is another option. Although I see that as a deterrent more than anything else.
I have sensors around my house too, I do like to have them.
Im using HKC wireless PIR Cams with pet lenses in. I do get the odd false alarm but as i can take a picture via the app i dont worry.
However these are internal devices i fitted them externally to test.
False alarm?
