durcanservices Posted December 6, 2017 Posted December 6, 2017 The mag locks on an internal door of a commercial office building aren’t going to be there to prevent intruders, that will be the job of the external locks and intruder alarm systems. These internal locks aren’t going to be a non compliance, but I would agree that you inform the building owner of the risk from such a design and offer them a more secure solution. Quote
al-yeti Posted December 7, 2017 Posted December 7, 2017 20 hours ago, durcanservices said: The mag locks on an internal door of a commercial office building aren’t going to be there to prevent intruders, that will be the job of the external locks and intruder alarm systems. These internal locks aren’t going to be a non compliance, but I would agree that you inform the building owner of the risk from such a design and offer them a more secure solution. Non compliant for what ? Access control? Quote
satsuma01 Posted December 9, 2017 Posted December 9, 2017 What about changing the fixings for the mag locks.to the frames to security screw type fixings with none standard heads or needing.the proper tool.for.the screw or.bolt removal Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
sixwheeledbeast Posted December 9, 2017 Posted December 9, 2017 It's not the fixings that's the issue. You can easily pop a mag, as it relies on the contact surface area. 1 Quote
sjsturner Posted December 9, 2017 Posted December 9, 2017 17 minutes ago, sixwheeledbeast said: It's not the fixings that's the issue. You can easily pop a mag, as it relies on the contact surface area. QFA Quote
norman Posted December 10, 2017 Posted December 10, 2017 A butter knife opens most. Quote Nothing is foolproof to a sufficiently talented fool.
