Hi all,
I've recently been given a dedicated micros ds2 which I'd like to get up and running. Can it be ran through a network without a display connected to the unit itself? If so, will the dedicated micros keyboard still work? cheers
Display or no display it can sit on a network and be accessed via NetVu, you will need a display to configure the IP details or if it's set to DHCP you could potentially find it through the NetVu software under Temporary Image Servers and go from there into the configuration pages.
*Keyboard only operates a local screen unless you also have remote screens connected via NV1's (pick a point system for instance)
*from memory, may be wrong.
